mmWave Axial Choke Horn Antenna with Lens
Download PDF
Millimeter wave (mmWave) antennas operate in the band of frequencies where the wavelength is between 10mm and 1mm. The frequency
range for mmWave application is thus constrained to be greater than 30 GHz, but less than 300 GHz. Various applications exist in
this frequency range, including wide band telecommunication and imaging applications for security screening. This white paper
demonstrates how an antenna was designed for communication at 60 GHz.
