Weld Distortion Optimisation using HyperStudy
Download PDF
Distortion induced in parts due to the cooling of welds complicates automated manufacturing lines in the automotive industry. The resulting deformation leads to additional investment such as end of line machining to correct affected assemblies. Utilising optimisation software a welding pattern can be found which retains the intended performance of a part while reducing the distortion induced from welding. Weld locations may be optimised alongside welding sequence to allow process requirements to be considered within the early design stage. This leads to high performance, low distortion assemblies which can ultimately be manufactured at the lowest possible cost.
