Case Study: Integrating Systems Modeling with Simulation Helps Ensure Robust Space Debris Removal
Download PDF
The European Space Agency (ESA) is studying an active debris removal mission called e.Deorbit which is intended to capture an ESA-owned derelict satellite in low orbit and safely crash it into the ocean in a controlled atmospheric reentry. The Airbus Defence & Space proposal for this project used Model Based System Engineering (MBSE) to simultaneously define the mission requirements and the architectures. In a parallel internal study, Airbus DS engineers used ModelCenter Integrate and MBSEPak to integrate the simulation tools used to evaluate the performance of the architecture with the system model.
