Explicit Dynamic Simulation of Tool Drop on the Outer Wing of the Swift020 Unmanned Aerial System using Radioss®
Download PDF
The successful launch of a new platform UAS is a comprehensive design engineering and manufacturing endeavor. The full lifecycle must consider maintenance and replacement components. As these requirements often require the use of tools (i.e. screw drivers, wrenches, pliers), the concern became apparent that as the flight surfaces are minimum gage, heavy tools dropped on the structure could cause irreparable damage. The objective of this project was to determine the specification for maximum maintenance tool weight such that, if dropped from a nominal height of 0.762 meters, would not cause permanent damage to any part of the Swift020 UAS. The Altair solution included a Radioss Explicit Dynamic Impact Simulation.
