Skip to main content
< Back to Search Results
Radar Cross Section of Aircraft with Engine Inlets
Download PDF
At radar frequencies, 1GHz and above, asymptotic methods are usually preferred to calculate the radar cross section (RCS) of targets like aircraft, since the main parts of the target are more than an order of magnitude larger than the wavelength. The challenge is how to combine these methods to compute the RCS. In this white paper the two-step method that obtains accurate results in limited time is detailed.
