Altair OptiStruct – Manufacturing Constraints Support for Multiple-Material Topology Optimization
Download PDF
All manufacturing constraints are supported for Multiple Materials Topology optimization (MMAT) from v2019.1.Different manufacturing constraints could be applied to different candidate materials in the same design domain. The original material defined by property will not be taken as candidate material by default. OptiStruct will error out if there is only one candidate material defined for the same design domain in MMAT.The element density result is available for all candidate materials in v2019.1.
