In this white paper, we present the innovative commercial GPU-based Computational Fluid Dynamics (CFD) solver Altair ultraFluidX. This work features simulations of the DrivAer model, a generic, publicly available vehicle geometry that was developed by the Chair of Aerodynamics and Fluid Mechanics at the Technical University of Munich and which is widely used for testing and validation purposes. The DrivAer model features rear end, underbody designs, and underhood flow. This model was then used to perform both wind tunnel tests and numerical simulations of the 40% scale open cooling geometry using perforated aluminum sheets with different opening ratios to mimic different radiator properties. Within, we will compare some of the results from these wind tunnel tests with numerical results obtained with Altair ultraFluidX.
